Hello,
Recently I had to restore the original backup factory tune to my PCM. In the process, my custom tune was lost. I did save the tune to my laptop, but that was 9 years and 3 laptops ago. I am continuing to search for the missing file so I can re-import it to the predator. What file extension does it use? If I can't find it, is there anyone that would be willing to share theirs if I can match their specs close enough?
Thanks.
If anyone is able to help find a tune...
2003 Mustang GT 4.6
Running 93 Octane
K&N cold air
BBK 75mm TB
Magnaflow catted x-pipe, cat-back system
180* T-stat
3:73 Ford Racing Gears
Need a tune to match:
- manual transmission
- rev limiter: 6100
- speed limiter: 255
- COT: Off
- Torque Management: Off
- Traction Control: On
- Rear O2s: On (maganaflow catted x does not trigger)
- Fans -15 degrees from factory
- Idle speed: Stock
- Max Timing in upper RPMs is: 20 to 23 degrees
- speedo adjustment: 3:73 gears
Lost my Custom Tune
Re: Lost my Custom Tune
It will be a .frg file
Thanks Mike. If I can not find it, is there some place that can write me a tune for a low price?
