7135 with R18 worked on first new log then started crashing
Posted: Mon Nov 26, 2007 4:03 pm
by sweetsrt8
I updated to the new R18 and created a new log that worked. However I created another log following day with just timing and Rpm and Knock ST/Lt and the dataviewer crashes just like when R17 was installed. Any help?
RE: 7135 with R18 worked on first new log then started crash
Posted: Mon Nov 26, 2007 5:10 pm
by johnc
I just recorded and downloaded a log just fine from a 300 SRT8, using R18 and those exact same PIDs. Please repeat the crash and email me any runtime.txt file and download.log file that you find in the same directory that you installed the DataViewer to.
Posted: Mon Nov 26, 2007 6:00 pm
by sweetsrt8
Sorry I didn't list all my PID's.
RPM
1/1 LTadap
2/2 Lt adap
Knk Lt Retard
Knk St Retard
pdl_pos_%
Spk_Cyl1-8
I will attach the runtime.log next
Posted: Mon Nov 26, 2007 6:03 pm
by sweetsrt8
I tried to attach the files to my post but I keep getting error about me trying post an empty file. I know the files are not empty, I can open them on my PC?
Posted: Mon Nov 26, 2007 6:07 pm
by sweetsrt8
One thing odd I did notice is looking back at handheld recorded log, my 2/1 LT Adap at several times reads out 12797.27 and 1/1 Lt adap is 1.17. That value can't be real can it?
Posted: Mon Nov 26, 2007 6:18 pm
by johnc
The file attachment feature of this forum doesn't work. Just attach the files to an email - my address is in my signature below.
Posted: Mon Nov 26, 2007 6:22 pm
by sweetsrt8
Done! Thanks for the help!
Posted: Tue Nov 27, 2007 9:19 am
by johnc
Email received. That log file has the same issue from R17 that was (supposedly) fixed in R18. Would you verify for me that your Predator says R18 above the main menu? And this log was definitely recorded after the CROM update was completed? Sorry to double check, but I want to be sure before I go cause trouble for someone.
Posted: Tue Nov 27, 2007 4:45 pm
by sweetsrt8
Yes sir, I see Predator v.8r18 on the hand held menu. And yes I had recorded it after applying the r18. I did another run last night and tried to use the dataviewer with a new log and it crashed again. Do you want the log files from that run? Thanks for the support guys!
Posted: Tue Nov 27, 2007 5:27 pm
by johnc
No, what I have should be enough. Thanks Brady.
Posted: Wed Nov 28, 2007 12:07 pm
by johnc
Try this new release:
DataViewer 3.1.5.4
I implemented a workaround for the broken log files.
Posted: Wed Nov 28, 2007 5:10 pm
by sweetsrt8
Excellent! I'll try it now and let you know. Thanks again for the help!
Posted: Thu Nov 29, 2007 3:36 pm
by sweetsrt8
Seems to be working fine with that release! Thanks a bunch!
Posted: Thu Nov 29, 2007 4:17 pm
by johnc
Sure thing. Sorry about that issue.
