Problem with drivers
Alex___
Post by Alex___ »
Hello i am from Sweden so excuse my Spelling.
I have a problem with installing the second part of the DS download to the Trinity is comes upp a screen that says that the language is not supportet for installing this drive or somthing like that its hard to translate, so the computer cant se the divice i have tried to change to English but still doesnt work any ideas?
Re: Problem with drivers
http://www.diablosport.com/forum/viewto ... 00#p252000
you need to change the Region and Language settings from the Control Panel... you need to set it to U.S. English instead of french...
Alex___
Post by Alex___ »
Thanks that works but now i get Another error when i registerit says
An erroro occured while trying to retrieve data from ther server
(no respnse). Are u connected to the internet? Are you running a firewall on your PC.
Connected to the internet and tested without firewall?
And when i press (ok) Another error comes upp that says
XML parsing error:`no element found`at line 1?
Alex___
Post by Alex___ »
solved it changed som letters and then is said that the devise has been registred but with an error screen i dont know but is seems to work.
