just bought a puck
Posted: Tue Nov 27, 2007 11:48 pm
by rtkota360
I have an 03.5 ctd with the 250hp motor.You guys say 60 and 90 hp gain.Is that with the HO or can i expect it with my motor as well?
RE: just bought a puck
Posted: Wed Nov 28, 2007 12:26 pm
Yes, you will see those gains.
Posted: Wed Nov 28, 2007 4:24 pm
by rtkota360
I just installed my puck today.Then I started it to leave,I let it warm up for a bit since its 36 out today and when it went to go into a high idle for warm up it had a "rough idle" like a fast wawawawawa.even if i pushed the pedal to lower the rpms it just did it slower.i drove a couple of minutes to the store and still did it when i parked.I came out and was fine and is fine now.Is this normal?Is it a cold temp thing?I started it on stock by the way.
Posted: Wed Nov 28, 2007 5:27 pm
Yeah, sounds like a cold start thing, no biggie.
Posted: Thu Nov 29, 2007 11:05 am
by rtkota360
are you sure this is normal?because it never did it before I put in the puck.Also should I get an EGT gauge?Is that something i have to worry about with this,I already have a turbo back 4" exhaust too
Posted: Wed Jan 16, 2008 4:42 pm
by GRI
if you run it on the stock setting it should tell you if it is different but it sounds like the warm up mode
