u7130 crom update.
Posted: Tue Sep 24, 2013 11:16 pm
by 05 work truck
Please need some assistance.... I have a predator u7130 with missing or corrupt application. I have tried to update with crom files 04,07 and 09.. all with no luck and still displays missing or corrupt file. What do I do now?
Re: u7130 crom update.
Posted: Wed Sep 25, 2013 12:42 pm
does it load all the way, or stop at a certain point?
Posted: Wed Sep 25, 2013 5:14 pm
by 05 work truck
It loads all the way and when if reboots if still says corrupt.
Posted: Wed Sep 25, 2013 5:43 pm
05 work truck wrote:It loads all the way and when if reboots if still says corrupt.
try loading this one.
Posted: Wed Sep 25, 2013 8:19 pm
by 05 work truck
Works perfectly thanks..
Posted: Thu Sep 26, 2013 9:31 am
05 work truck wrote:Works perfectly thanks..
ok, you should load this now.
Posted: Fri Oct 04, 2013 2:24 pm
by balvert
I had the same problem. Tried everything suggested. Didn't take 9r09, 9r08, or the versions found in the links in the discussion. Finally was able to install 9r04 which is what I had in the first place. Not sure what the change is in that latest update but it is not worth trying again.
Posted: Tue Feb 09, 2016 2:16 am
by mjalstad
I had the same problem when loading 9r09. I tried it twice and both times it got all the way to the end and said that it was corrupt. I tried loading the 9r08boot file and the same thing happened, then I retried the 9r09 file right after and it worked!
