Long story short, I smoked my V6 fan. Im getting it replaced but I want to make sure the settings are correct so it doesn't run all the time. I do have a 180 stat that opens about 178 degrees.
I updated my crom the other day. I do have a CMR custom tune. I checked in the modify tune section and I have only 3 fan settings to work with
1. HIGH MPH HS FAN ON
2. LOW MPH HS FAN ON
3 HS FAN ON
they where all 3 set on 184.99
After asking around I was told to set them like this
HIGH MPH HS FAN ON 188.59
LOW MPH HS FAN ON 188.59
HS FAN ON 193.99
My main concern is there is no "FAN OFF " settings? Is this normal and does this look good?
V6 conversion fan settings.
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
Re: V6 conversion fan settings.
I think the 2 188.59 numbers are when the fan kicks off
Then the hotter 193 number is when they kick on?
