diablo maf focus 2.0 16v zetec
MAF.i.a Support
julien
Post by julien »
hello I'm french sorry if my English is not correct.
I buy from the cfm performance diablo maf for my Focus 2.0 16v 130PS. I have a turbo kit on my reach 10 12psi I have cut gasoline :oops: . I wonder if the maf diabo solve the problem?
on what setting it should be 0-1-2-3-4-5-6-7 meter thank you
Re: diablo maf focus 2.0 16v zetec
you must custom tune the vehicle for use with the Mafia, it is not a bolt on device. You'll need to find a tuner to work with to set it up properly.
julien
Post by julien »
ok thank you. therefore diablo maf will not solve the problem of fuel cut?
not by itself, no.
julien
Post by julien »
I tested 0-7
0: running 12psi boost but cut off 4500k
1: works but cut engine failure
2: No break my motor saturates manometer indicates lean air fuel no power
3 grazes engine 1000k max
4 engine browses 1000k max
5 engine browses 1000k max
6 engine browses 1000k max
7 works but some 4500k cut
100% internal stock
obx turbo turbo kit t3/t4 TO4E
  19lb injector stock ecu
camshaft comp cam stage 2
fidanza aluminum wheel motor
clutch stage 3
garrett
Site Admin
Post by garrett »
you need to get a custom tune to dial you in. You cant just put a Mafia on and expect it to work.
julien
Post by julien »
I put 5 psi of boost I did not cut of fuel, I will mount 30lb injector is what diablo maf recalibrated injector size?
or should I install the maf proM 30lb ?
julien
Post by julien »
probleme resolue injecteur 315 cc avec régulateur stock 3.8b débit injection 355cc 0.7b de boost mafia diablo régler sur 2 plus de coupure d'essence :) merci a maf. ia diablo sport pour se boitier
Return to “MAF.i.a”
