My truck wont start "no ecu found" help !!!
Michaeldavis35
Just tried loading a tune for the first time... I have updated my intune and did the calibration update... THen i went to plug it into my truck and it went up to 100% and said there was an error in the calibration update... So I tried one more time and same thing. THen I call tech support and they gave me a code to type in and told me it would work ... But now it is saying there is no ecu and my truck wont even start and tech support is closed.... Please help I have to have my truck running so I cant get places...
Michael
email
Michael
Michaeldavis35
Re: My truck wont start "no ecu found" help !!!
MY truck is a 2011 ram 1500 4x4 and I have dcx intune 1000 btws truck still wont start
turbohawk80
Connect the tool to the PC
When prompted to enter recovery, select cancel
When prompted to reset tool, select cancel
With the main menu showing, drag the attached file to the Intune drive and let the tool import the firmware.
Once the tool loads the new firmware, take it back to the truck and let it attempt the recovery again.
Michaeldavis35
Still says no ECU found
turbohawk80
did the new firmware load correctly?
it may say no ecu a few times, just keep hitting the green check. the third time should continue on.
Michaeldavis35
it acted as it installed correctly and it says all updates are up to date.. ANd then it said calibration update error and then I called tech adn they reset something and said it would work and it didnt and then i installed the new file you sent me and have tried it 5 times in a row and it still says no ecu
turbohawk80
if the tool had already been reset, I can't do much.
you'll need to contact tech on Monday and RMA the tool and ecu
Post a copy of the info.xml file from the intune drive please so we can see if you got the update loaded.
Wait...when you called tech, they would have clearly asked if the truck was running before they reset the tool. If it was running when they did that, what happened to cause it to not start?
Michaeldavis35
Tech never asked me if my truck was running... I drove the truck home turned it off, went inside to get my tuner to try it out for the first time and just turned the key to the "on position" and thats when the problems started with the calibration error, so I called tech and they made me give them a number off the tuner and they told me to enter a pass code and I did and then I tried to do load tune again and all it said was no ecu found and I tried calling tech back and no answer and then it was about 4:30 CST so I figured they closed so I thought Ill just wait till monday and I went to start my truck and nothing just a whole bunch of warning lights aI vnd my red security light flashing ... ive tried unplugging battery and that didnt change anything
Michaeldavis35
Ive tried posting the updates and it just says the extension url is not allowed what are your hours I cant get anyone to answer the phone for tech support
Michaeldavis35
ok I cleared out all updates on my dcx 1000 and I unhooked battery and ecu for 30+ mins and reloaded the update and tried again and it still say "no ecu found" which means my truck still wont start... Ive been trying to call all day (monday) and never get an answer... Ill try back tomorrow and hopefully we can get this worked out cause its been 4 days now with no truck...
Please give all the information you have to the tech you are speaking to in email.
pontiactree1
Same problem with my 1999 corvette did u get help
