Ford lightning canned tune
Posted: Sat Nov 02, 2013 3:43 pm
by across281
I am looking at buying a predator for my 02 lightning (intake, exhaust, 2#). I am curious about the canned tunes that come on the DSP. I have heard the 91 octane tune is meant more for a 4# pulley because of the duty cycle.. I am currently gettin 16hwy and I would actually like to increase that but I feel it will not help if more fuel is being dumped into the system. So I guess I was hoping someone could tell me about the tunes, if there was one that would increase mpg with stock boost or with the 2lb-er. Before Someone says well why didnt you buy a prius I have a new job that requires me to make a 600m drive 4x a year.
Re: Ford lightning canned tune
Posted: Mon Nov 04, 2013 11:03 am
by sohfast94
Couple things.
We don't just randomly dump fuel into the engine. It's a MAF so it's based on airflow entering the engine so if there is less, there will be less fuel. Nothing generic. You may be a degree or two low on timing but that can be adjusted with the tool so there's no worries there.
Please feel free to ask any other questions you may have.
Posted: Mon Nov 04, 2013 11:50 pm
by across281
So say I flashed the 91 oct tune on stock boost will I see in increase in gas mileage? I have a 2# pulley also but I am just wondering if I will get any benefit with a tune on the stock size ring on quick change kit
Posted: Tue Nov 05, 2013 12:09 am
by across281
I FOUND THIS INFO
Does the predator come with these tunes uploaded onto it?
2001-2004 Lightnings
(CXN1, ABU2, NLP2, and URB1 box codes with factory Lightning 90mm MAF only):
Non-pulley tune 87 octane: tune for 87 octane and stock pulley
Pulley 87 octane: tune for 87 octane and pulley, max 13-14 PSI
Non-pulley tune 91 octane: tune for 91 octane and stock pulley
Pulley 91 octane: tune for 91 octane and pulley, max 13-14 PSI
Non-pulley tune 93 octane: tune for 93 octane and stock pulley
Pulley 93 octane: tune for 93 octane and pulley, max 13-14 PSI
Factory hp tune: Factory tune, use this to modify adjustable parameters. Use with Factory recommended octane.
Posted: Tue Nov 05, 2013 9:54 am
by sohfast94
All of those tunes it comes with.
Posted: Tue Nov 05, 2013 3:33 pm
by across281
Awesome, thanks for everything!
