Why does it keep updateing back to 1r01t
Posted: Thu Nov 07, 2013 8:06 pm
by bullfrog69z
Installed the update 1t01t and when I plug it to my computer it keeps updating back to 1r01t and loose tcm support until I reinstall 1t01t back. Will their be a update to fix this issue?
Re: Why does it keep updateing back to 1r01t
Posted: Fri Nov 08, 2013 9:58 am
by garrett
What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
Posted: Fri Nov 08, 2013 1:53 pm
by bullfrog69z
garrett wrote:What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
Thanks ,, that the problem. I hit check for updates. Will their be a new update for the test version soon.
Posted: Fri Nov 08, 2013 4:08 pm
by garrett
technically, 1r01t is NEWER than 1t01t
Posted: Fri Nov 08, 2013 6:41 pm
by bullfrog69z
garrett wrote:technically, 1r01t is NEWER than 1t01t
Oh. But it doesn't have tcm support in it. ?? :cry: I like the tcm settings. Hope the next update will resolve the issue and still be able to stay updated. :wink:
