OBD2 trouble code scanning for all makes.
acascianelli
Post by acascianelli »
Why is it not possible to scan trouble codes of any OBD2 car with a Predator tool? It seems like something that would be so simple to do. These tuners cost $400 and you can only use them on whatever make and model you buy them for.
I have 2 others cars and it would be nice to be able to use my Predator to scan and clear trouble codes on my other cars.
2007 Mustang GT
Steeda CMCV Delete Plates
Steeda Underdrive Pulley
Bamachips Race Tune
Sequential Tail Lights
Hurst Short Shifter
Pypes O/R X-pipe
C&L Racer Intake
RE: OBD2 trouble code scanning for all makes.
if you buy a FORD tool, it will only work for FORD vehicles, with the same OBD bus....
for instance, I have a 2006 Monte Carlo - these are OBDII with a CAN communication bus...
so my predator will scan ANY GM/Chevy that ALSO has a CAN bus.... but it will NOT scan a FORD...
acascianelli
Why can I go rent a cheapo scanner from Murrays that will work on any make and model...
2007 Mustang GT
Bamachips Race Tune
Hurst Short Shifter
Pypes O/R X-pipe
C&L Racer Intake
Thats because it is simply a code scanner, not a tuner.
We build tuning tools that just so happen to also do diagnostics on the applications supported by that tool.
Return to “General Questions”
