Just updated and my Truck is not in the list
Posted: Thu Nov 21, 2013 6:39 pm
by Geophrum
Ok so i detuned my Charger as it is away for the winter and am moving the trinity to my 2004 Ram 1400 with the 5.7 hemi. plugged it in and it said i needed to update, so i pull out my trusty laptop and plug it in and use the dsdownloader to update it. said it was successful. While still plugged into the laptop I went and started looking options to select the vehicle and it does not have the 2004 dodge ram 1500. it has the 2500 with the diesel. it says that the truck is supported... what can i do now?
Help
John
Re: Just updated and my Truck is not in the list
Posted: Thu Nov 21, 2013 6:49 pm
by Geophrum
Ok selected the 2005 dodge 1500 that is the earliest 1500 that is there.. but when i plug it into the truck it repeats its self over and over again Please turn the key to on blah blah blah hit ok, it things again and then pops up "please turn the key to the on position and do not start the engine...
John
Posted: Thu Nov 21, 2013 7:03 pm
Geophrum wrote:Ok selected the 2005 dodge 1500 that is the earliest 1500 that is there.. but when i plug it into the truck it repeats its self over and over again Please turn the key to on blah blah blah hit ok, it things again and then pops up "please turn the key to the on position and do not start the engine...
John
load this update, select 2005, and go :)
Posted: Thu Nov 21, 2013 10:18 pm
by Geophrum
Mike, as usual, you rock.. that worked.. thank you!
Three hemi vehicles, one with a predator, the other two share the Trinity for now.. Spring time, I will be buying a new intune for the truck.. (or maybe replacing the predator) so i wont have to keep swapping. Would i need the same crom on the new intune or should that come with it? or maybe newer by then?
John M
Posted: Fri Nov 22, 2013 9:26 am
Geophrum wrote:Mike, as usual, you rock.. that worked.. thank you!
John M
no, this issue was specific to trinity... :)
