Not sure if DS allows this, but is it possible..
vig
Post by vig »
To get the "specs" of a 93 diablo tune for my 2006 corvette base. I'm asking because it's raining bad here and will be for a few days so I can't do a datalog to get the canned rpm shift points and firmness specs because I want to start off with little increments because I'm such a newbie. If I'm driving a stick I shift by feel, so I don't even know what rpms I used to shift at (obviously I know "around" where I shifted, but want exact numbers). Another example, when I was checking out parameters today I was looking at idle and driving rpms and you can adjust +\- 50 but not sure what the canned tune is set at. (I would rather have been able to set it at 600 rpm for example). Same thing for firmness, you can adj +\- 1 but I have no idea what it's set at? I hope I'm making sense because being such a newbie I may be looking at this all wrong. Thanks guys. Ps I have an intune if that makes a difference (06 base A6 vette)
Re: Not sure if DS allows this, but is it possible..
shift points are not changed in the preset tunes, they are left at stock..
idle/driving rpms are not changed in the preset tunes, they are left at stock...
shift pressure is usually bumped up in the preset tunes, by about +15% to +20% more than stock...
vig
Post by vig »
once again, Thanks Lew :D
Return to “General Support”
