Dual tunes possible?
jasinedward
Post by jasinedward »
I have a friend that uses a competitor tuning device. He claims to have a custom tune that allows him to run a different (nitrous) tune at the flip of a switch. He says it is built into the tune itself. Is this possible with an Intune? Vehicle is a 2013-14 Mustang GT
Re: Dual tunes possible?
no it's not possible...
what he's most likely doing is using 2 pcm's... and flipping the switch makes the car use one pcm or the other....
BlackZ71Silverado
Post by BlackZ71Silverado »
jasinedward wrote:I have a friend that uses a competitor tuning device. He claims to have a custom tune that allows him to run a different (nitrous) tune at the flip of a switch. He says it is built into the tune itself. Is this possible with an Intune? Vehicle is a 2013-14 Mustang GT
Black Bear Performance does similar tunes. They can give you two totally seperate custom tunes using the same PCM/TCM. The tunes are switched by pressing the tow haul button in our trucks. You can switch from one custom tune to another just by pressing the button.
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
yeah, using different software and a custom operating system on the pcm....
not something that can be done with a handheld or diablo's software, since it keeps the stock GM operating system, so you can restore the original backup stock tune to the vehicle without having to worry about warranty issues.. ;)
BlackBear is a bunch of scumbags. Can't deal with a little competition on the forums. They go whining to the mods when you bring up DiabloSport.
:twisted:
sohfast94
Post by sohfast94 »
06MonteSS wrote:no it's not possible...
It is possible with the 11up mustangs. I just haven't looked into it enough yet to see what they're doing.
Insert Clever comment here...
jasinedward
What they're doing is adding a switched resistor to the temp gauge. Once the switch is activated, it shoots the temp gauge to 240. The tune he has pulls timing when the temp gauge reads 240. This way, he doesn't even have to restart the car.
jwdemon
Post by jwdemon »
Well that's not a separate tune, they're just forcing the pcm to pull timing for the nitrous!
