Jeep Wrangler Miss Fire counters
Posted: Tue Dec 31, 2013 11:54 am
by PRS
I have a 2013 Wrangler Unlimited that I have installed the Ripp supercharger on. I have had fuel ratio issues since the install and am trying to track down the problem. I found the miss fire counters in the Trinity and presumed they are for each cylinder, since there are 8 counters "MF counter current 1" 1-8. The only one that is counting is 3 so I wanted to ensure that there have not been problems counting the missfires in the other cylinders.
Do they all work?
Re: Jeep Wrangler Miss Fire counters
Posted: Fri Jan 03, 2014 12:14 pm
yes...
Posted: Sun Jan 05, 2014 10:00 pm
by PRS
That was short and to the point.
Just to clarify, if any of the other cylinders are misfiring the counter for the specific cylinder should increase the count, correct?
And the counter should go back to 0 whenever you shut-off the engine and restart?
If that is all true, then I should move the injector from #3 and observe the counters to see the miss move to the other cylinder.
Posted: Tue Jan 07, 2014 10:53 am
PRS wrote:That was short and to the point.
correct.
i doubt its the injector, but worth a shot.
