reading the knock sensor
Posted: Tue Jan 28, 2014 8:41 am
by heli4me
On the trinity under knock retard there is a smaller window
Bottom. Looks like. 00/00
Is the numbers on the left side that show in negative timing being added and the right
in positive a knock?
Example. -25/.50 Is this 1/4 deg timing added along with 1/2 deg retard or knock?
Lol hope I asked this correctly
thanks.
John
Re: reading the knock sensor
Posted: Tue Jan 28, 2014 9:48 am
by sohfast94
-25 would be pulling 25 degrees. .50 would be adding .5 degrees.
Posted: Tue Jan 28, 2014 11:02 am
by heli4me
So all numbers at the bottom left side of the knock guage be counts of knock?
I will attach a couple data logs for you to look at latter tonight if you have time
Posted: Tue Jan 28, 2014 1:02 pm
by sohfast94
Yes please. So I can make sure we're on the same page.
Posted: Tue Jan 28, 2014 7:47 pm
by heli4me
here you go there is two
logs... how much knock, timing retrd and advance are you seeing
Posted: Tue Jan 28, 2014 8:01 pm
by heli4me
here is a log with the same set up with no knock
just a different tuner that wrote tune
why is the knock dead quiet are the sensor turned on?
i have included a copy of the tune file
JOHN
Posted: Wed Jan 29, 2014 10:40 am
by sohfast94
The knock sensor is in fact off in that tune you posted.
Posted: Wed Jan 29, 2014 11:09 am
by heli4me
On the other logs what did you determine for knock counts and timing retard or advance
thanks
Posted: Wed Jan 29, 2014 1:14 pm
by sohfast94
At 7:15 is adding .75 of a degree
At 7:19 is taking out .25 of a degree
Posted: Tue Nov 21, 2023 3:56 am
by alicebobby
In that tune you posted, the knock sensor is indeed malfunctioning.
retro bowl college
