No DOD after custom tune
WTO
Post by WTO »
The vehicle is a 2008 Silverado K1500 LTZ 5.3 with LT headers, no cats, smooth intake elbow & high flow filter. After running the log files and getting it dialed in I wanted to turn DOD back on. After the header install, with the Diablo tune DOD worked fine. Nothing was changed in the "final" tune but DOD was turned back on, didn't work. I put the Diablo tune back in & it worked fine. The last tune sent to me is the Diablo tune with the rear O2's off but DOD still does not work. Any ideas?
TCM_24245713_LastTuneWritten.grg
(14.49 KiB) Downloaded 122 times
ECM_12631658_LastTuneWritten.grg
(55.95 KiB) Downloaded 123 times
Predator model U7191 (06 GTO)
iNTune i1000 (08 Z-71 LTZ)
2008 Z-71
03 Polaris SP 600
Re: No DOD after custom tune
yeah Mike, when you see this tomorrow... I have the DOD enabled/on in the custom tune, yet he's saying that DOD is not working/engaging when he drives the truck?? Any ideas??? first time I've come across this issue, so I asked him to post up about it, maybe you have seen it before???
WTO - post up your original backup stock tunes as well please....
thanks!
post the backups please.
WTO
Post by WTO »
Here they are, sorry it took so long....
TCM_24245713_Backup.grg
(14.41 KiB) Downloaded 132 times
ECM_12631658_Backup.grg
(56.31 KiB) Downloaded 128 times
2008 Z-71
03 Polaris SP 600
WTO
Post by WTO »
Please look @ this and let me know what the solution is.
2008 Z-71
03 Polaris SP 600
everything looks OK.
try this new file, see if you get DOD to engage.
ecm_12631658_newdod.grg
(51.88 KiB) Downloaded 120 times
WTO
Post by WTO »
I wish I could report back that DOD works now but it does not. :cry:
Attached are copies of the last tunes and the backups.
(14.42 KiB) Downloaded 121 times
(14.41 KiB) Downloaded 128 times
(55.9 KiB) Downloaded 119 times
(56.31 KiB) Downloaded 119 times
2008 Z-71
03 Polaris SP 600
I dont believe it is an issue with the tune at all....
WTO
Post by WTO »
If I put it back stock, or install the Diablo tune, DOD work's fine but my check engine light is on because of the missing cats. I nstall the custom tune & it stops working, what else could it be?
2008 Z-71
03 Polaris SP 600
WTO wrote:If I put it back stock, or install the Diablo tune, DOD work's fine but my check engine light is on because of the missing cats. I nstall the custom tune & it stops working, what else could it be?
Ahh, for some reason I thought you guys were saying that DID did not work in the stock tune now either.
If it is just with Lews tune, I'll have to see if I can get more eyes on this.
WTO
Post by WTO »
Thanks for the quick response. I'm going to put less final tune back in until you have a new one to try. Truck ran great with the final one I just wanted DOD back on to try and get my MPG up.
2008 Z-71
03 Polaris SP 600
