failed to update reset TCM adaptation...
cq842000
Post by cq842000 »
Hey I'm using an Intune DCX with the latest software on a 2012 Charger SE (V6 w/ 8 speed trans), and on previous software revisions I could reset the adaptives for the TCM, but the last four or five revisions keep returning an error after getting to 10% and hanging for a moment no matter if I try it through quick adjusts or adjustable parameters. Is this a bug, and is it due to be fixed soon?
cq842000
Re: failed to update reset TCM adaptation...
Post by cq842000 »
I forgot to say thank you in advance.
hmmm,that has been fixed int he past....should be a quick fix.
can you post a copy of your info.xml file here please?
cq842000
Post by cq842000 »
mikel wrote:hmmm,that has been fixed int he past....should be a quick fix.
Here it is Mike thanks for the prompt response.
info.xml
Edit...
Guess that fix wasn't so quick after all?
have you reloaded the tunes since you updated?
Can you post a copy of your backup file and last tune written from the tunes folder please?
cq842000
Post by cq842000 »
mikel wrote:have you reloaded the tunes since you updated?
Yes I have restored factory and reloaded my custom tune since updating. Here are the files you requested.
PCM_68084713AH_Backup.drg
PCM_68084713AH_LastTuneWritten.drg
you say you have a custom tune...any chance you have an old copy of the tunes from when you got the custom tune?
Do you recall tcm adaptive reset working at that time?
cq842000
Post by cq842000 »
mikel wrote:you say you have a custom tune...any chance you have an old copy of the tunes from when you got the custom tune?
Unfortunately I update my backup folder when I see that the tunes work. About four or five updates back, the TCM reset worked. That being said, the TCM adaptation reset Stopped working before I ever got a custom tune.
Ya know, now that I think about it, TCM reset worked two updates ago. The PCM was recently replaced with a new one, would that have anything to do with this problem?
Oh and the PCM backup was made before I got a custom tune. I flashed the canned 93 octane Diablo tune at the time of that backup.
cq842000
Post by cq842000 »
Did you ever come up with anything?
maybe I shouldnt have said quick, it will not be something that happens in an hour, but a couple days should work.
cq842000
Post by cq842000 »
mikel wrote:maybe I shouldnt have said quick, it will not be something that happens in an hour, but a couple days should work.
Alright man, thank you for your time.
cq842000
Post by cq842000 »
I'll keep checking this thread.
cq842000
Post by cq842000 »
Its been a good while. Did you ever come up with anything?
cq842000
Post by cq842000 »
Bump...
cq842000
Post by cq842000 »
Any updates yet?
