i just bought a mustang and i came with a predator,,
it has the current firmware because i updated it and even on a stock tune the readiness test will not change for the o2 and cat from incomplete..
i understand the older firmware allowed you to cut o2 on and off and current doesn't....
basically i need to have my o2's turned back on for emissions ....
any way to downgrade to older firmware or a way to change a custom tune to simply cut o2 on? i have mil eliminators i just need them on for emissions!!???
u7146 opps!... and question
Re: u7146 opps!... and question
well, we cant edit the stock tune, so if they are off there somehow, you have a problem.
If it is not passing stock, its more likely another issue, as opposed to the tune itself...
brettlaw83
Is there a way I can upload the original back up and check weather rear o2's are in fact turned on or off?
I had a similar issue with previous Mustang where the o2s were disabled before the tuner was added and got an email tune with them cut on
post the file here.
brettlaw83
here is the one .
i used ds downloader and "chose get from tool"
- CRAI8DC-diablobackup.frg
- (224.25 KiB) Downloaded 237 times
the file is 100% stock, as delivered by ford, all monitors are enabled, nothing turned off.brettlaw83 wrote:here is the one .
brettlaw83
Thanks alot for checking!
Now when I used Downloader to send you that file, which tune did it pull from tuner? Like was that the backup, current, or custom?
backup file.
