dealer said pcm is fryd!!!
sdphillip619
So i was trying to change my 2013 300c back to stock had a pcm error writing and car would not start i took it to dealer and they are saying my pcm is done and not covered under warranty even tho i have 22k on it i think the dealer is bullshittn me about the pcm please help
Re: dealer said pcm is fryd!!!
get your car back, give us a call with the tool powered up, and if we cant recover it remotely, we'll call tag it, fix it here, and overnight it back.
We dont believe in fried PCMs...
mbell2zero
I have a 2011 ram r/t with a trinity tuner on it. Was on my way home from south carolina back to ny and about half way my truck went into limp mode. pulled over shut the truck of turned it back on and it ran fine for prob another 30 miles then same thing. again reset it and found that if i kept my truck in 5th so it wouldn't go into 4cyl mode it wouldn't go into limp mode. when i got home hooked the truck up to the snap on scanner at work and it showed 15-20 codes. Called the dealership and can't get it in till the end of next week. Anyone else have this happen or know what may cause it??
if it happened while driving down the street, something failed, the tune would not have anything to do with it...mbell2zero wrote:I have a 2011 ram r/t with a trinity tuner on it. Was on my way home from south carolina back to ny and about half way my truck went into limp mode. pulled over shut the truck of turned it back on and it ran fine for prob another 30 miles then same thing. again reset it and found that if i kept my truck in 5th so it wouldn't go into 4cyl mode it wouldn't go into limp mode. when i got home hooked the truck up to the snap on scanner at work and it showed 15-20 codes. Called the dealership and can't get it in till the end of next week. Anyone else have this happen or know what may cause it??
What are the codes? Can't even begin to diagnose without them.
mbell2zero
The 2 codes that come up othe tuner are p0884 tcm power input signal intermittent, and p0653 sensor reference voltage b circuit high. They seem to all have to do with high and low voltage. The truck has 48,000 miles on it this is the first winter its seen. Oil changed every 3000miles with valvoline synpower full synthetic.
Im sure we can fix it.
mbell2zero
What should I do?
this is what you should somikel wrote:get your car back, give us a call with the tool powered up, and if we cant recover it remotely, we'll call tag it, fix it here, and overnight it back.
