Just made a datalog
Posted: Tue Mar 11, 2014 4:49 pm
by FitzysGTO
I just took two drives down the highway at a constant rpm/mph. Got home plugged into my computer and opened with Dataviewer. saved it as a csv and opened up the csv in dslog and it said that I need to put my inj slope down to -12%. Went into the car and adjusted the inj slope to -12% in the diablo tune. Does having to decrease the % of the slope mean I was running rich or lean? I haven't driven it yet to see if it made a difference. will it? I also put in my wheel size too. is there anything else I need to know? I attached my two logs.
Re: Just made a datalog
Posted: Tue Mar 11, 2014 5:55 pm
by 06MonteSS
going negative on slope, makes the injectors spray MORE fuel, makes you richer...
so if you went -12%, then you were running lean... so that adjustment will make it spray 12% more fuel to richen it up...
Posted: Tue Mar 11, 2014 8:26 pm
by FitzysGTO
Would the Diablo tune made it that lean?
It was around 50 degrees today when I did the log. now its going to get colder. will this change the slope again? should I run the log again when it gets warmer??
Posted: Wed Mar 12, 2014 8:43 pm
by 06MonteSS
no.. the diablosport tunes do not change/adjust the part-throttle fueling at all. so no - it wouldn't have made it lean... you were lean to start with...
Posted: Thu Mar 13, 2014 3:33 pm
by FitzysGTO
I would guess that I was running lean because of the Vararam intake. thats the only mods I have.
