crashed
crashed
Hi I am very new to this.i got the trinity last night i did everything i was to do.when i went to plug it into my 2005 dodge magnum RT i had to do a update to the pcm.so i did so then when it was done i loaded it into the car.when at the end i got faild tcm 116 can not finsh up date.tried 2 times no go.it was getting late and i was getting somewhat mad.so i went to go start my car and now runs bad no power misfire codes.i had to scan it with my scanner that i have.codes are p1411 and p1414.i think my pcm is fried.now what do i do.if i get a new pcm and try to install the trinity i am going to get the same thing.can i call tecsupport.
Re: crashed
does the vehicle start and run at this point? if not, please give us a call in the vehicle with the tool as soon as possible.
Re: crashed
yes it does start and run.went down to a performance shop and they had this happen 3 times this year.i disconnected to battery like you had said.all is good now.but they told me not to plug it back in the car.there is a problem with the trinity.so I would like to do that.send it back and see if you guys can fix it.they are telling me its a soft ware problem.or do you guys just send me a new one?please let me know thanks guys.
Re: crashed
ok.cars runs good.now I still would like to get the trinity up and running.but only ? I have is should I go to the dealer to get my pcm updated or still go threw u guys.
Re: crashed
dodge doesn't update their pcm's. they'll just write what you had on there when you 1st bought the car.Brian1974 wrote:ok.cars runs good.now I still would like to get the trinity up and running.but only ? I have is should I go to the dealer to get my pcm updated or still go threw u guys.
the updates diablosport does is that same dodge program but modified for better performance (more or less)
Re: crashed
ok.i will be putting in the new cailb.for which I got to do frist before I put the 93cai tune.the frist time I got a tcm error.i have been on the forums all weekend so if I got this error I should call them.i really want this tune.my car is a 2005 dodge magnum RT with a k@n CAI with full exhaust system.i have heard this should take car of my lean problems that I get on the high way.
