Lost - Help
mgood
Lost - Help
Post by mgood »
I get to here:
And this screen comes up:
"logs" and "runtime" are empty folders.
When I click "tunes," I get to here:
Closer view of same:
I can't seem to open any of that. Or anything else related to the inTune that makes any sense.
Handheld unit looks like this:
If I touch any button on the touch screen, it goes to this:
The three main buttons are gone. The back button is grayed out. The ? button is there but does nothing. Touching the screen anywhere does nothing. It's locked up, done, finished, until I unplug it and start the process over. I end up back here every time. :|
Am I taking a wrong turn somewhere or do I have an equipment problem?
And what program do I use to open the Backup and LastTuneWritten (GRG files, whatever that is)? Or are they anything I need to open?
Are there other tunes I can find and look at? Where?
I'm using Windows 8 BTW :roll: (Still learning my way around 8.)
2004 Chevy Silverado 1500 4x4 Z71 5.3L 4L60E 3.73:1
on Toyo Open Country A/T II 295/75R16
now running Diablo inTune!
mgood
Re: Lost - Help
Post by mgood »
I'm not sure what I was expecting it to do.
Maybe it's done all it's supposed to?
I know the tech support guys won't be in until tomorrow, but if someone could tell me whether or not what I'm seeing looks normal to them, it'll help.
I probably won't be able to mess with this during business hours tomorrow, so just in case tech support wants to look at something, for whatever reason, I'll include the files.
PCM_12587685_LastTuneWritten.grg
(31.41 KiB) Downloaded 179 times
PCM_12587685_Backup.grg
(31.48 KiB) Downloaded 185 times
info.xml
(1.82 KiB) Downloaded 190 times
Re: Lost - Help
you have installed the tunes....what is the actual issue?
mgood
Re: Lost - Help
Post by mgood »
mikel wrote:....what is the actual issue?
I guess there is no issue. I thought I was supposed to do something else to it, but I guess it did what it was supposed to do. :P
When I found the manual, that helped. RTFM
