2011+ Chrysler 200 / Avenger 3.6 Tuning
Posted: Sun Mar 16, 2014 12:18 pm
by untouchable4206
I got my Intune DCX the day the update was released and am glad I did. Took me a while to get the settings tuned in, but finally drives like a dream. Still waiting on some small fixes with some tuning parameters, but LOVIN' THE TUNER!
Here are my before and after numbers using Torque Pro and my Google Nexus Tablet.
Each run was done 3 times with a 5 minute break in between.
***Stock hp with 89 fuel: 224 avg***
***Stock hp with 93 fuel + nitrous: 304 avg***
*** 93 tune with 93 fuel and ethanol mix: 245 avg***
Tune seems to work and pulls harder. Torque mgt also seems to be gone...bout time.
***93 tune with 93 fuel and ethanol mix + nitrous: 326 avg! :drivingbad: ***
Thanks again Mike and keep the updates coming. :D
Re: 2011+ Chrysler 200 / Avenger 3.6 Tuning
Posted: Sun Mar 16, 2014 1:58 pm
by red200s
I am impressed with the results by the 93 tune on my 200.
Which parameters didn't seem to work? I'm also curious if you could get higher numbers on a tank of pure e-85 and not a mix. Great research and numbers!
Posted: Sun Mar 16, 2014 4:27 pm
by untouchable4206
The redline rpm limit is finicky, tire size select doesn't work, and disable traction and abs doesn't work at all.
Did finish tuning my 93 tune and it is perfect! Some fuel adjustments were needed. Here is a sound clip of the new tune since the sound changed. Sounds nasty.
Posted: Mon Mar 17, 2014 9:41 am
i cant imagine how tire and tc disable dont work, I just did them on a 2011 200S the other day, but we'll sort it out, along with the neutral rev limit, etc :)
enjoy ;)
Posted: Mon Mar 17, 2014 2:41 pm
anyone with the rev limit issue, please post a copy of your info.xml file from the intune drive, so we can get that fixed asap.
Posted: Tue Mar 18, 2014 8:40 am
by untouchable4206
Here is a copy of my info file. Question, i updated, registered and then tuned my car with the dcx. A few said something about calibration. Mine never said anything about that? Neutral rev works, rpm limiter in d stopped working( back to factory setting), tire size says failed to read parameters and the traction diable says the same.
Here is another clip of my exhaust sound since it changed when I tuned last. Thanks loads Mike!
Posted: Sun Mar 23, 2014 10:55 pm
by untouchable4206
Hey Mike, any word on the bug fixes for our cars. Some of my parameters are still not working and I cannot get a straight answer from the techs I talked to. First I was told that the TC disable would go away when the key was off and revert back to factory always on and I would have to reflash to disable it again since DiabloSport doesn't have the ability to keep it off in the tune. There are several people in the A2OG group that have gotten their tc disable to work and theirs stays off even after multiple engine turn off's and restarts. What's going on??
Still not working on my 2012 200 3.6:
Tire size change: doesn't concern me, but still can't access it through the tuner. Says failed to read parameters.
TC disable: Says failed to read parameter.
neutral limiter is still 50/50
rev limiter in d has completely failed to work now.
Posted: Mon Mar 24, 2014 11:12 am
untouchable4206 wrote:Hey Mike, any word on the bug fixes for our cars. Some of my parameters are still not working and I cannot get a straight answer from the techs I talked to. First I was told that the TC disable would go away when the key was off and revert back to factory always on and I would have to reflash to disable it again since DiabloSport doesn't have the ability to keep it off in the tune. There are several people in the A2OG group that have gotten their tc disable to work and theirs stays off even after multiple engine turn off's and restarts. What's going on??
fixed here:
Posted: Mon Mar 24, 2014 5:51 pm
by cblood
Is this also a fix for those of us with 2013 Avengers that are unable to tune at all?
Thanks!
Posted: Mon Mar 24, 2014 6:58 pm
by untouchable4206
Nope, still not working. Same things not working. Saying failed to update Traction Control.
Here is a short clip of the error i am getting.
Intune DCX Failed To Update: https://youtu.be/4ArmD6VLYtM
Posted: Tue Mar 25, 2014 10:37 am
untouchable4206 wrote:Nope, still not working. Same things not working. Saying failed to update Traction Control.
post the info.xml file please
Posted: Tue Mar 25, 2014 11:09 am
by untouchable4206
here is my info file.
