Autostick
Posted: Thu Dec 06, 2007 2:37 am
by SRT8GUY
Am confused about enabling or disabling autostick i had the 1-2 flash done car now upshift on it's own with the new update does that mean i can go back to manual shift as it was when i first bought the car if not can someone please explain what the autoshift fix is all about sorry for sounding so dumb
RE: Autostick
Posted: Thu Dec 06, 2007 9:50 am
by johan
Yes if your vehicle is not an 07 SRT8, then you can disable the auto upshift when in manual mode using the predator.
Re: RE: Autostick
Posted: Thu Dec 06, 2007 11:15 am
by SRT8GUY
johan wrote:Yes if your vehicle is not an 07 SRT8, then you can disable the auto upshift when in manual mode using the predator.
So what you're saying is that with the predator i can put my car back to stock before the 1-2 flash meaning when in manual i have to up shift if so will it down shift on it's own or do i have to down shift manualy just want to made sure i understand correctly
RE: Re: RE: Autostick
Posted: Sat Dec 08, 2007 4:30 pm
by SRT8GUY
I guess no one can answer i'll check someplace else
Posted: Sat Dec 08, 2007 7:10 pm
by Jected
Your car is classed as an 07 SRT8 if it was built 09/06. You will not get Autostick disable to function with R17 and this will also screw up other fuinctions relating to the trans. For example downshifting in Autostick and Drive shift isssues.
You best bet is to put your car back to stock, download the latest R18 update and reinstall to your car. This will solve all of your issues.
Alternatively, if you require the functions and benneifts of the Autostick disable feature similar to the 05's and 06's, you need to purchase a TCM for those cars.
Hope that helps.
Re: RE: Re: RE: Autostick
Posted: Sat Dec 08, 2007 7:39 pm
by SRT8GUY
Jected wrote:Your car is classed as an 07 SRT8 if it was built 09/06. You will not get Autostick disable to function with R17 and this will also screw up other fuinctions relating to the trans. For example downshifting in Autostick and Drive shift isssues.
Hope that helps.
My car is a 2006 thanks for the info i checked it out myself and found out that i can disable Auto upshift
RE: Re: RE: Re: RE: Autostick
Posted: Sat Dec 08, 2007 7:44 pm
by Jected
Sweet as no probs mate
