Registration Code
Registration Code
Registration Code has not come. Been awhile. should I call the company?
Re: Registration Code
I activated it for you, should be all set next time the updater runs on the PC.
recently updated my new dcx, everything seemed to go smooth except the registration. can not get a registration code emailed to me. not sure if this is an issue or not, thanks mike
It should be activated now.
Thanks Mike. Do I need to anything else on the pc or is it good to use Saturday. Getting the car out of storage
All good.
Ive read on here about the push button ignition and people not turning it on and off when the tuner tells you too. any suggestions. I had a 2010 challenger and had no problem with the push button on that with the tuner but the 2011 is a new breed
pop it out and use the key
Mike, I installed the tune Saturday with no issues at all. Thank you for the comments and answers. I do have a couple questions though. Originally installed the 93 tune and seemed like the car was jerky between gears, it a 6 spd stick, hard to explain but like the rpms dropped off really quick and when upshifted and let the clutch out was under revving. Doint know if Im explaining it right but it was jerky. I tried the 91 tune and its much better. Guess I don't understand why that would make a difference. Also before the tune, stock, it shifted a lot smoother. Seems like the idle is lower with the tunes? @nd question, my 10 challenger had an issue every once in a while with shifting form 1st to 2nd and I just found out about shift skip on a forum Im a member of. After the Intune I never had an issue with it and didn't realize till tonight what it was. I traded the 10 for a 11 and did the tune last Saturday and am still getting the shift issues. Does the 1000dcx disable the shift skip like the 1000 did?
thank you
thank you
post the tunes from the tunes folder and I'll take a look.
Where do I get them from
connect the intune to your computer..
go into the inTune drive that shows up on your computer...
go into the Tunes folder..
just got home, I am going to try and post the tunes Mike
cant figure out how to send the files to the post
