Chevy SSR Thermostat
Posted: Thu Dec 06, 2007 3:37 pm
by arizdare
I already have the diablosport predator tune installed in this car (2006). I was thinking of changing the factory thermostat (190degrees) to the aftermarket 165 degrees.
would the current tune adjust itself or do I have to do anything with the predator?
thanks,
Mark
RE: Chevy SSR Thermostat
Posted: Thu Dec 06, 2007 5:44 pm
the tune won't adjust itself...
you would have to go in and play with the fan adjustments to really see any benefit, if any....
Posted: Thu Dec 06, 2007 8:56 pm
by arizdare
Makes Sense, thanks!
Posted: Thu Dec 06, 2007 9:15 pm
by arizdare
Have you changed your thermostat in the LS2 to the 160?
Posted: Thu Dec 06, 2007 10:08 pm
I have an LS4 5.3L... no, didn't change mine.. stocker is 180....
Posted: Sat Jul 02, 2011 5:35 pm
by arizdare
I checked the change parameters and the lowest number in degress for changing is 192. then it goes up the 190's and into the 200 degrees, 210 and I think the highest was 220 degrees. but the coolest was 190 or 192.
When I changed the stock rear end from the 390 to a 410 I contacted diable and they sent me a program to download to adjust the speedometer. I thought I should call and ask them personally?
today at 2pm right now the temperature out side is around 122 degrees if you could see why I really would like to get this fan temp lowered to come on sooner than 190's.
thanks for any help...Mark-Lake Havasu City, Arizona
Posted: Sun Jul 03, 2011 11:12 am
can't... can't change the fan temps... can only change the % power that the fans run at...
you can not change the actual temps... 192* is the lowest setting you can change the fan power for...
Posted: Sun Jul 03, 2011 11:42 am
by arizdare
[quote="06MonteSS"]canThey were able to send a download to adjust the speedometer for the 410 gear I changed. I will call them tuesday. I cant see why changing the fan setting to come on at the 165 degree level instead of the 192?
you mentioned changing the % power that the fans run at?
thanks again for taking the time for your input!
Mark-Arizona
ps. this part of the countyr is in its monsoon season. I walked outside with the dogs about 5am. the temp was already at 92 but the problem was the humidity is near 50%. we moved here from chicago and that humidity is the worse! dont get me wrong. I lived in chicago all my life (duty disabled chicago cop). we moved here about 10yrs ago and I wouldnt trade this weather for the midwest for nothing.
anyway, thanks again!
