I-1000, gears and afr help.
cooper1965
Post by cooper1965 »
Re: I-1000, gears and afr help.
post the tunes from the tunes folder and we'll set up the gears for you in a custom tune.
cooper1965
Thank you for such a quick reply Mikel, I will post those file's first thing in the morning. Thank's again!
cooper1965
Here are the files you requested.
PCM_09358575_LastTuneWritten.grg
(26.18 KiB) Downloaded 130 times
PCM_09358575_Backup.grg
(26.46 KiB) Downloaded 149 times
johan
Post by johan »
Here you go
pcm_09358575_323.grg
(24.1 KiB) Downloaded 143 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
cooper1965
Thank you johan!
Can anyone provide some insight into my other question about adjusting the injector slope without using any AFR data?
if it's saying you need to adjust -12%, you have issues.. you shouldn't be running that lean for only a cai mod...
sounds like you have an air leak or leaks somewhere...
check everything under the hood.. make sure the cai is fully together, all clamps/bolts TIGHT so no air leaks there, all vent/breather tubes connected where they should be, etc...
