Cooling Fan Controls
certifiedking01
Im using an InTune. Under the cooling fan features, I would like them to kick on at a lower temp. These options are confusing to me. The degrees that u adjust the slider to indicates when the fan kicks on?
Re: Cooling Fan Controls
what vehicle are we discussing here??
certifiedking01
Dodge Caliber SRT-4
I also would like to know how to do this on the same vehichle
certifiedking01
Let me explain why its confusing to us owners. The stock reading has a line graph from 115-255 degrees give or take. As soon as you try to move it one degree down. It jumps to 230 degrees, then after that you can move it one degree at a time. Why is that? Also if you move the degrees down to 200, does that mean the fans wont kick on if temps raise above 200? The settings also displays high to med, low-high, med-low. What do these define? What happens if all of the categories in the fan settings are set to the same degrees? Or if they overlap?
