2006 dodge - U7131 DIABLO SPORT
djensen9367
Post by djensen9367 »
Considering buying one of these w/power puck stack (when available).
1. On level one and two, does it smoke?? I tow all the time (5000 lbs) and smoke is NOT an option as it soots up my trailer to much. I do have a quad std. that will supply boost fooling when turned off which i assume will help with the smoke issue. Not worried about smole so much on upper tunes as will rarely use.
2. When will the stack combo be available?
3. Also read about the 1000 volume (change on the fly) option which was supposed to be available Mar 7th. Where can I read on this, when will it be available, and aprox cost
tried e-mailing sales a few days ago but no one seems to want to respond.
Any help would be appreciated
johan
RE: 2006 dodge - U7131 DIABLO SPORT
Post by johan »
1/ If you refer to the programmer level one and two, which would be the tow and performance tune, you will only get a puff(light haze) of smoke if you romp on it if you gradually increase throttle you will have no smoke. The extreme and extreme rkl will emit quite a large PUFF of smoke when romping on it and a haze when staying on it. We try to reduce smoke as much as possible as it just wasted fuel.
2/Stack combo should be shipping this week.
3/ Switch on the fly is still being worked on and no info on it is available at this point.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
djensen9367
thanks, that is what i was looking for. I assume with boost fooling smoke is even reduced more.
2006 3500 quad (bighorn), 3.73 w/ auto, dunrite triple,qzilla std., amsoil nano filter,Donaldson 51". Airride 5th wheel, airride receiver hitch, jacobs brake, brakesmart ,35' Newmar 5th wheel, pace 14' ,GDP Gfs-392 Walbro w/2 Micron Filter :)
johan
Post by johan »
It will reduce the smoke during wot, it will not reduce the puff of smoke when stomping on it.
Diablosport INC
Return to “Predator Ford Gas”
