"pcm error unlock for reflash (-1)"
Posted: Sun May 04, 2014 2:59 pm
by delo
i have challenger 2011 V6 3.6L and when i try to add the booster tune to 20% on the car, i always had "PMS error unlock for reflash (-1).
T-1000 diablosport
i did the new update for the tuner. no aftermarket things.
91 octane tune installed.
what is the problem?
any ideas
Re: "pcm error unlock for reflash (-1)"
Posted: Mon May 05, 2014 12:02 pm
will it load the tune with no changes?
Posted: Tue May 06, 2014 4:18 am
by delo
mikel wrote:will it load the tune with no changes?
i did the tune to 91 octane, and all good . but when i tried to do the booster tune to 20% i get always this error "pcm error unlock for reflash (-1)"
Posted: Tue May 06, 2014 9:57 am
can you post the info.xml file from the intune drive please?
Posted: Fri May 16, 2014 3:30 am
by delo
mikel wrote:can you post the info.xml file from the intune drive please?
where can i find the file ?
Posted: Fri May 16, 2014 9:04 am
on the drive called intune when the tool is booted up on the PC.
Posted: Wed May 28, 2014 12:33 am
by delo
mikel wrote:on the drive called intune when the tool is booted up on the PC.
i can not find the file and having big trouble understanding where actually , so im hoping you could give me a step by step instruction, any ways i found this is tool info :
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM6 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6QGOT20-4'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r11c 04/22/2014 06:01:20 PM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 0
Marriage VIN :
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
Posted: Wed May 28, 2014 9:05 am
well, i see the problem.
This is the intune section of the forum, and you are using a Trinity
Lets start over...
Posted: Wed May 28, 2014 9:06 am
options/show information, what is the version, and options/troubleshooting/show calid, what is listed there?
