predator 7.3 not recognizing the ignition - help
Posted: Sat May 10, 2014 6:07 pm
I have a predator 7.3 and have used it for years with only one previous issue with an invalid license issue which was resolved by a Diablo sport technician back in 2008. I have backup the orginal tune and reloaded the 60 hp tune altered with a firm shift many times over the years. I mostly leave the 60 hp tune in but ocassionally do a restore when I need to put the vehicle a shop especially the dealer. When I recently went to backup the original tune the tuner did its normal cycle saying:
- booting ford 7.3
- the main screen appears
- I select performance tune
- I select restore backup
- it says turn the ignition on, no errors or message at this point
- it tells me to turn off the ignition
- it then says to turn on ignition and the second time it says the ignition is not on or I have a chip.
this happens if I attempt to do a back up or reload the 60 hp tune.
Does anyone have any idea as to what could be causing the tuner to not recognize the ignition? I am wondering if there is something wrong with the tuner or if something is wrong with my truck but everything on the truck is functioning including the key and anti-theft system and it doesn't matter what key I use as I have tried several keys and have also disconnected the battery a couple of times thinking that may help.
I appreciate any response!
- booting ford 7.3
