U7198 adjustments (upshift MPH vs TP)
I have a custom tune to help the rough shifting and I got my LTFT's dialed in, now the truck runs great. I have not adjusted the PE cuz I do not have a wideband to monitor the setings. I was reading about some of the adjustments that other members have made and someone said that they maxed out the (upshift mph vs tp) setting and it gave him better throttle response. Well I tried this but only changed it to 30% and WOW what a difference! When cruising between 25 and 55 if you step on it ,the truck just wants to go. Normally it would take a second to downshift and then go. After reseaching these boards Johan said that he does not change these peramaters unless you change gears. Will this hurt anything with stock gears? I know that it holds the gears a little longer, but what if any are the down sides of this change?
2000 GMC Sierra 5.3 2wd ecsb
Denali cluster
Denali headlights
Corsa sport
Outlaw intake
U7198 custom tune (93)
03 Silverado taillights
debadged
shackels
20" wheels
RE: U7198 adjustments (upshift MPH vs TP)
ttt
Denali cluster
Denali headlights
Corsa sport
Outlaw intake
debadged
shackels
20" wheels
camarofool
It means to the top.
Denali cluster
Denali headlights
Corsa sport
Outlaw intake
debadged
shackels
20" wheels
There are no downsides to this change, other than maybe losing a bit of mileage as the truck will hold gears a bit longer.
