I just purchased a Predator U7198 version 2.13 for my trans am. I went in to adjust the shift pressure and noticed that it says WOT shift pressure and not just shift pressure like the manual says. What does it mean by WOT? Is it different then just changing the shift pressure? Is my predator different or do they all say WOT? Also how do you know if your predator is a SLP tuned predator? Can you tell by the version?
thanks
Predator GM U7198???
RE: Predator GM U7198???
WOT means wide open throttle. I have the same tuner for my truck and right underneath wot pressure should be the part throttle settings.
2000 GMC Sierra 5.3 2wd ecsb
Denali cluster
Denali headlights
Corsa sport
Outlaw intake
U7198 custom tune (93)
03 Silverado taillights
debadged
shackels
20" wheels
what tunes does it have on it? 91 octane tune, Diablo Tune?? if it has tunes names like that, then it's a regular diablo predator...
the slp predators have their own custom slp tunes on them.
where did you buy it from??
I bought it off ebay. The guy said he used it on his truck. Im using it on my 2002 trans am. He said its only a few months old. It has the lastest version of 2.13 so I guess it is. It has the performance tune or stock tune. Not the 91 or 87 octane tune. Is mine different from a regular predator then? I put in the performance tune and the car runs amazing. I just want to make sure its the right programmer. Like in the manual it says that you can tune for 87 octane but you cant in mine because it only has a perfomance tune or stock tune. Plus in the manual it says shift pressure but mine says WOT shift pressure. Is mine like all the other U7198?
RE: GM U7198???
2.13 is the latest version of the U7198.
You should have both WOT and part throttle shift pressure adjustment.
Thanks! Thats what I wanted to hear. The predator is amazing. I would bet it added atleast 20 rwhp or more. Its the best performance upgrade I have done to my car so far.
