Caliber SRT4 93 Tune Overboosting!
Posted: Sun Jun 08, 2014 11:35 pm
by cccamuseme
So I ha had my 93 tune loaded for over a week now and it still is over boosting and pulling throttle at 20+ psi. At Wot shoots past 20 and bounces from 19 to 21 the whole time. I have triple check lines and did a boost leak test and everything is good. I am running stock WGA set with barely any preload. Mods are HKS BOV, catless o2/DP, check valve off and 4" intake.
I recently modified parameters by decreasing boost in Trinity (WG 4k-7k) by 25% and it seems to be holding at 19 but I shouldn't have to be modifying these.
Can someone help me out?
Re: Caliber SRT4 93 Tune Overboosting!
Posted: Mon Jun 09, 2014 12:35 pm
the catless DP may be contributing, is the tool fully up to date?
Posted: Tue Jun 10, 2014 9:15 am
by cccamuseme
Yes the tool is fully up to date.
Posted: Tue Jun 10, 2014 9:18 am
by cccamuseme
I disconnected and reconnected the battery and drove around on backup tune for a while before reinstalling 93 tune. Now it spikes past 20 but then levels out at 19 and holds.
Posted: Sat Jun 14, 2014 11:01 pm
by cccamuseme
How do I see Knock (STKR) viewing the log using Trinity. I don't see anything.
Posted: Mon Jun 16, 2014 10:09 am
its in there, maybe listed as LTKNK and STKNK?
Posted: Tue Jun 24, 2014 3:15 pm
by cccamuseme
When I go to the viewer, I do not have a misfire section for the PID's. How do I add this?
Posted: Tue Sep 20, 2016 7:30 pm
by Christian1994
I have my dodge caliber set on thw 93 octane tune and it's over boosting. It wont pass 10 psi without lagging. I installed an aftermarket blow off valve so I did a few adjustments to the vacumm lines. I need info ASAP thank you. What can I do so it will stop over boosting or lagging?
Posted: Wed Sep 21, 2016 8:20 am
if you rerouted the factory vacuum lines, you've created boost control issues, Id suggest redoing them or look into a custom tune.
Posted: Sun Aug 13, 2017 11:48 pm
by Cgreen95
Hey I'm new to all this tuning stuff and I just installed the trinity t1000 on my 2008 Dodge Caliber Srt4 and I'm having some issue. I've installed the 93 octane tune and everything installed fine but when I was out testing driving it I found that when I got on it my turbo would have studder or skip in almost like it wasn't getting enough of something and I was wondering if you guys could help me out. Only upgrades are three inch catback into a 4" mpx muffler. Thanks
Posted: Thu Aug 24, 2017 12:39 am
by 4drturbo85
Cgreen95 wrote:Hey I'm new to all this tuning stuff and I just installed the trinity t1000 on my 2008 Dodge Caliber Srt4 and I'm having some issue. I've installed the 93 octane tune and everything installed fine but when I was out testing driving it I found that when I got on it my turbo would have studder or skip in almost like it wasn't getting enough of something and I was wondering if you guys could help me out. Only upgrades are three inch catback into a 4" mpx muffler. Thanks
Hopefully you have a wideband.... Any time you mess with a factory tune and boost you should have a wideband and you need to monitor knock.
