Hi! I was just wondering went we put in the custom tune from hemifever the throttle booster is set at 0%. Does the throttle booster is already adjust in the custom tune. Not sure what to do raise it or live it the way it is.
Thanks for the response!
Throttle Booster
Re: Throttle Booster
the tune already has the throttle boost adjusted, but you have the ability to adjust it up to 20% higher than what it is already set at.
I have confirmed with Sean and the custom tune he does is already set at 20% although the Trinity will show at 0%. If you add 20% you will be at 40% increase. Not sure how 40% would be or what benefit it would be that high.
