So I was driving into work this morning running a power puck on my 06 cummins with the switch in the 90hp position. I was just cruising with traffic when the check engine light came on and I lost all power pretty much.
I read the codes and got p0238 turbo/supercharger boost sensor A circuit high and I got p0113 Intake air temperature sensor 1 circuit high input.
I cleared the codes but havnt driven it since I had to get into work.
The is the first time driving with this unit on my truck.
any help would be awesome.
thanks
will
power puck causing codes to pop up on 06 cummins
Re: power puck causing codes to pop up on 06 cummins
did you buy it used or new?
any corrosion on the connectors?
got it from a buddy so it was used. ill check and see if there is any corrosion on the connectors. im pretty sure when I hooked it up yesterday the plugs looked good but ill look again.
will
will
what year was it installed on previously?
06 also. I also have a diablo predator from the same guy but I need to do a reflash cause im getting a error saying I need to have the dealer update.
should just need to update the device to the latest versions.
