AEM Air Temperature Sensor
prerace
Post by prerace »
I have a customer who had an AEM air temperature sensor installed in the charge pipe of their 2004 SRT4. They are running on a Trinity tuner and I cannot find any fields in the CMR software that allow me to scale this sensor into the tune. They are also throwing a P0111 (intake air temperature) code although I don't know if this is for the intake air temp or the inlet air temp which I will find out once they come in. Can anyone direct me as to where to find a scaler table or voltage table to get this sensor functioning properly?
Thank you,
Erich
Re: AEM Air Temperature Sensor
I doubt we ever added scaling for the IAT as I've never heard of anyone changing that before, i would advise just putting the stock one back in there.
prerace
Post by prerace »
Any chance this could be added to what I'm sure is a long list of updates? Our customers are bringing us more and more complicated setups and the factory ait sensor is very poorly designed and leaks boost at the grommet where it goes into the charge pipe. I can change to a different sensor from AGP that matches the stock curve better but they damage very easily and it would be nice to be able to install the more universal GM sensors and tune them accordingly.
Thank you,
Erich
we'll look into it.
You're looking for something like this? ;)
http://ft.trillian.im/c78b81634d41d8730 ... eqrps5.jpg
sohfast94
Post by sohfast94 »
Here is 03-05 non-stage cal templates.
Put them here: C:\Chipmaster Revolution\Template
It will be under functions -> powertrain configuration -> Intake air temp transfer function
05029832ae.tpl
(19.2 KiB) Downloaded 143 times
05029415ah.tpl
(19.86 KiB) Downloaded 148 times
05029242ai.tpl
(15.76 KiB) Downloaded 151 times
Insert Clever comment here...
prerace
Post by prerace »
sohfast94 wrote:Here is 03-05 non-stage cal templates.
Thank you very much!
