U7135 Autostick Auto upshift
orangehemi
Post by orangehemi »
Question is, I have a 08 SRT8 Challenger, Within the 93 tune, in Transmission adjustments Autostick Auto Upshift you have 4 Modes to choose from , Stock , Mode 1,2 & 3 . What does each Mode mean ? or do ?
Thanks !
Re: U7135 Autostick Auto upshift
stock is stock no change, the other 3 will make auto stick behave differently, but how is up to your specific calibrations, best to try them and see which you prefer :)
orangehemi
I thought each Mode , Mode 1 , Mode 2 & Mode 3 were pre-programmed from you guys, there is not a way to look at the parameters within each mode, nor are they adjustable ,
orangehemi
On another quick note ,. can you guys come up with a 91 Tune w/ a 100 HP Nitrous shot ? Is that something you can e-mail me so I can upload to the handheld ?
thats something you can do with the tuner itself to just pull some timing at WOT.
orangehemi
Sure , as we all know you can raise the shift points & How Firm, as well as Rev Limit, but the Auto Stick Modes give no example of What each Mode does , of course other than Stock , we know what Stock is....
Thanks !
right, as mentioned, the best way to see what they do is to try them, mode 1 for car A may behave differently than mode 1 in car B, so we cant really define them for you...
orangehemi
ok, sorry to keep beating this to death, but Im sure when you guys set up the programs within the Tuner for that certain car/ there must have been some sort of parameters or each mode would have no info programmed inside each mode, nor would it make any difference
which mode you selected if there were NO factory presets via DiabloSport. Im sure there are a few out there wondering about this same thing, However I do understand to just try each mode & note the difference , I just thought there might be a baseline to start from .
Your products rock ! I have used nothing but your tuners , they are the very best hands down !! :D
we didn't actually create those 'parameters', we saw different means that the OEM tools use to change the way the TCM behaves, and put them in the tool for the end users, which is why its tough for us to say how they'll behave exactly on each specific vehicle.
