Tune files
Tune files
I had my car dyno tuned and have been having trouble with them getting the tune right. I have had it back 4 or 5 times now and nothing seems to be better. Can I use the last tune written to give to another tuner to make changes to or would they need the actual tune file from the dyno tuner?
Re: Tune files
either way is fine as long as the custom tunes are not locked.
Re: Tune files
Perfect. I am having problems with the rpms hanging at around 1300 when I out in the clutch and come to a stop. It takes a few seconds or longer to come down to 800 after I come to a complete stop. I also have a slight stumble at 2800-3000 under regular throttle in every gear. They can't seem to figure those two issues out. Any ideas what it could be?
Re: Tune files
tough to guess, lets start with what kind of vehicle it is?
Re: Tune files
It is a 2006 Mustang GT with about 26000 miles on it. ProCharger P1SC-1 kit. Everything else is stock.
Re: Tune files
Diablo Lew mite be able to help you out with your tune, check with him.
Re: Tune files
Should I upload my last written file?
Re: Tune files
Diablew only tunes GMs.turboal wrote:Diablo Lew mite be able to help you out with your tune, check with him.
Insert Clever comment here...
Re: Tune files
Are you using the procharger supplied tune?jimadvig wrote:It is a 2006 Mustang GT with about 26000 miles on it. ProCharger P1SC-1 kit. Everything else is stock.
Is the check engine light on?
Re: Tune files
I am using a custom dyno tune. No check engine light.
