2010 Chysler 300C 180 thermostat CEL
richmonti
Post by richmonti »
I am using a Trinity to tune each of my Mopars, a 2008 Jeep SRT and a 2010 300C. I run a 180 T stat in both. No problems with the Jeep but the 300 keeps throwing a "P0128 coolant below temperature code". I am running the 87 octane MPG canned tune which I really like, as it works well with a drop in KN filter and RT muffler, giving a nice blend of performance and economy. The Jeep has a custom tune and has never had an issue with the T stat. My question is short of getting a custom tune is there any way to make an adjustment so that I don't keep getting the P0128 code with the 180 T stat? Thanks in advance for any help with this issue.
Re: 2010 Chysler 300C 180 thermostat CEL
Get a decent 180 stat from NAPA and throw the JET away. JET T-Stats have zero quality control and often throw codes because of poor warm ups.
richmonti
Post by richmonti »
So a different thermostat is my only other option?
Its probably your best option. You could have a tune written to turn the code off, but if you ever have to run without a tune, you're back to square one.
Post your Last Tune Written. They can turn the code off in the tune for now.
richmonti
Post by richmonti »
Thanks for the input Mike. For now I'll post the last written tune (tomorrow) and run that till I can do a T stat change.
richmonti
Post by richmonti »
Mike
Here is the last tune written to my 300C which is what I am presently running.
PCM_68052001AD_MPG_Booster_Tune_modified.drg
(2.25 KiB) Downloaded 199 times
I'll try the Tstat swap down the road when I have some free time.
here you go.
pcm_68052001ad_mpg_booster_tstat_fix.drg
(67.07 KiB) Downloaded 238 times
richmonti
Post by richmonti »
I loaded the tune today. :drivingbad: I plan to hit NAPA up for the Tstat you recommended and install it down the road. I'll post a follow up when I do. Thanks again Mike and thanks to Diablosport for continued great customer service. (That's a big part of why I have Trinitys for three of my vehicles) :mrgreen:
