PCM Calibration 1J4BA5H1XAL183322 might need an update. Check for calibration update?
I have the latest updates 1r04b. This happened right after the dealer did an update on the PCM. This is for a 2010 jeep wrangler. It doesn't want to go any further. I did the update a few times just to be sure. I cleared the updates from the intune and reloaded them again. Still in the same boat here. Is there something I'm missing.
PCM Calibration might need an update
- info.xml
- info
- (2.52 KiB) Downloaded 354 times
Re: PCM Calibration might need an update
it says the tool is already married to the vehicle, was it not restored before the dealer flashed it?
I'm also having the same issue. PCM Calibration for VIN might need an update. Check for a Calibration Update?
I also get, "No ECUs Found. Check ignition key"
It checks for codes, and it knows my VIN. What's the deal?
- info.xml
- (1.82 KiB) Downloaded 288 times
Here's another tidbit of info. I'm trying to set up on a PC. When I look in Explorer, I see my .xml file and three folders. For kicks, I looked on my Mac. I see all the files.
I copied the files to my PC, and they're now loading.
it went through all sorts of gyrations, and I get the same outcome: PCM Calibration for VIN might need an update
