Page 1 of 3
caliber srt4 boost won't adjust with handheld
Posted: Thu Jul 17, 2014 11:51 pm
by awd1990tsi
I have an intune and recently discovered that no matter what I adjust the boost control to in the tune it does not change the boost once installed. I found at least 2 others with the same issue that have the same calid as me. So decided to post here with advice from one of your calibrator to inform of the issue and search for a fix. My calid is 05187661AF
Thanks in advance
Re: caliber srt4 boost won't adjust with handheld
Posted: Fri Jul 18, 2014 8:49 am
all vacuum lines set properly?
post the tune files please...
Posted: Fri Jul 18, 2014 3:42 pm
by awd1990tsi
Vacuum lines are all routed correctly. I should clarify that it does increase from the stock 10 psi, up to the 18 psi of the diablo tune. Its just that when altering the adjustable parameters and loading the tune back into the car the boost pressure stays at the same 18 psi. I'm working on getting the tune files loaded but the boost control isn't changed on my last loaded tune. I put it back to 0% after I realized that altering it didn't do anything. Do you need both the last written tune and the original backup?
Posted: Fri Jul 18, 2014 3:47 pm
by awd1990tsi
Okay I've got them both off of the intune. let me know if you'll need anything more or want me to try anything.
by awd1990tsi
Last written tune.
Posted: Mon Jul 21, 2014 1:08 pm
by awd1990tsi
Bump. Need me to try anything?
Posted: Mon Jul 21, 2014 1:43 pm
by sohfast94
awd1990tsi wrote:Vacuum lines are all routed correctly. I should clarify that it does increase from the stock 10 psi, up to the 18 psi of the diablo tune. Its just that when altering the adjustable parameters and loading the tune back into the car the boost pressure stays at the same 18 psi.
Due to the nature of the computer in these things being torque based it probably won't let you raise it much past where I tuned it to in the first place. You would need the torque and pressure limits raised to do so. That is mostly there for people that may need to lower it for any reason.
Is there some reason you're trying to go higher?
Posted: Mon Jul 21, 2014 2:07 pm
by awd1990tsi
Well originally because when I got a rescale done for ns1 injectors he turned down the boost to be safe. Now I have monitoring equipment so I wanted to increase it back up.
Now I'm running the Diablo tune but it's running lean so I was going to try removing a little boost to keep afrs in check.
And lastly the biggest part is because the tool wasn't advertised as partially functioning. I'm not honestly sure the boost control is the only thing not working. So far it's still running lean and I've been increasing wot fuel. But maybe I just haven't increased that enough yet.
Posted: Mon Jul 21, 2014 2:16 pm
by sohfast94
Let's look a the steps here:
You got "bigger" injectors
Then had someone "rescale" them
And now you're running lean and can't seem to add enough fuel with the tool which does work to adjust the wot target AFR
So I would say it's your rescale, or your injectors are not what they are said to be. I say this because I've rescaled quite a few of these stage 1s already and have not had this issue.
Posted: Mon Jul 21, 2014 2:17 pm
by sohfast94
awd1990tsi wrote:And lastly the biggest part is because the tool wasn't advertised as partially functioning. I'm not honestly sure the boost control is the only thing not working. So far it's still running lean and I've been increasing wot fuel. But maybe I just haven't increased that enough yet.
Also before we start with the wild accusations. The tool works exactly as advertised....
Posted: Mon Jul 21, 2014 2:25 pm
by awd1990tsi
I've been using the base diablo tune since I found that I couldn't adjust boost on the rescale tune. Still can't adjust boost on the canned tune.
And yes bigger injectors are also running lean on the canned diablo tune. But I'm slowly trying to add fuel to get the afr consistently below 12.
In most of these cars I'd bet you are right. There is a small group of us though all with the same calid experiencing the same issue. Not a huge number only like 3 that I'm aware of. But still an issue with the tool playing nice with the caliber.
Posted: Mon Jul 21, 2014 2:47 pm
by sohfast94
Ok I'll flash to that calid and see what the deal is. Everything about the tune works as intended right? Are you at elevation or something?
Posted: Mon Jul 21, 2014 2:55 pm
by awd1990tsi
No sir. I'm in North western ohio very close to sea level. The tune itself makes a huge difference over stock. So it seems everything that was set by you is working fine. Just the adjustability of the handheld isn't functioning properly.
Credit where credit is due I'm very happy with the tune I love the throttle response and power. Just the random issues like this one that just need a little working out.
Posted: Fri Jul 25, 2014 3:58 am
by awd1990tsi
bump, any word?
Posted: Tue Jul 29, 2014 3:39 am
by awd1990tsi
Intune had an update so after it installed I attempted to alter the boost level lower and higher with no change in psi.
Hoped maybe the update would cure it but no such luck.
Any word on possible solutions yet?
