DTC P0128 2007 Jeep Grand Cherokee 5.7 low temp thermostat
Posted: Mon Jul 21, 2014 10:01 am
by 07Overland
Hi Mike,
I installed a Mishimoto 180 low temp thermostat, Mopar coolant + 1 bottle Lucas Super Coolant, and am getting DTC P0128.
I logged data while driving and the code only trips when the engine temp gets below 170 while driving. (It is 78 degrees today and engine is 173-176 degrees driving; up to 196 degrees idling.)
I see that you are able to fix the P0128 issue, if I send you my last tune can you fix for me?
We have sub-zero temps in winter, what is the lowest temp you adjust to so P0128 doesn't trip?
Also, it would be great if you enable thermostat adjust in the inTune: I realize that may take away custom tuning shops, but a low temp thermostat is such a great weekend project (generally less than $75 bucks for all parts and fluids and only an hour wrench time) that I would appreciate being able to modify with inTune on the fly.
Thank you,
David
Re: DTC P0128 2007 Jeep Grand Cherokee 5.7 low temp thermost
Posted: Mon Jul 21, 2014 10:11 am
post the tune please.
Posted: Mon Jul 21, 2014 10:28 am
by 07Overland
Hi Mike,
Thank you for the prompt response.
Please see PCM_05187053AH_LastTuneWritten.drg attached.
David
Posted: Mon Jul 21, 2014 10:49 am
07Overland wrote:Hi Mike,
David
here you go.
Posted: Mon Jul 21, 2014 10:53 am
by 07Overland
Awesome, thank you very much.
Do you mind if I ask how you fix on your end:
Do you adjust the temperature that trips the code?
Or do you make the tune ignore the parameter all together?
Posted: Mon Jul 21, 2014 11:27 am
just raise the thrershold for setting the code.
Posted: Mon Jul 21, 2014 11:38 am
by 07Overland
Ok great, thanks again for your help.
Your prompt feedback is some of the best client/customer support I've ever encountered.
2007 Chevrolet Trailblazer SS low temp thermostat tstat fix
Posted: Sat May 16, 2015 2:11 pm
by 07Overland
Hi Mike,
I purchased the diablosport from autoanything for my 2007 Chevrolet Trailblazer SS and am going to put a low temp thermostat in, if not too much trouble can you do the tstat fix on my tune?
Please see attached
ECM_12612850_LastTuneWritten.grg
TCM_24234613_LastTuneWritten.grg
Thank you,
David
Re: 2007 Chevrolet Trailblazer SS low temp thermostat tstat
Posted: Mon May 18, 2015 11:43 am
Please see attached
Thank you,
David
this thread is in reference to an issue with Chrysler vehicles, never been an issue on any GM I see....
Posted: Mon May 18, 2015 12:23 pm
by 07Overland
My apologies I though I started a new thread.
Thank you for following up. Will let you know if I get a temp error with the new low temp thermostat on the GM.
Posted: Wed Nov 23, 2016 1:06 pm
by 07Overland
Hi Mike,
My 2007 Jeep Grand Cherokee 5.7 is stalling while driving in cold weather.
You helped with t-stat fix on a tune but in trouble shooting the stalling I had to uninstall the aftermarket throttle body and put back stock.
Two questions:
1. Are there other temperature sensors or parts that have to reach a certain temperature car that will shut down engine?
2. With the new throttle bottle, if I re-submit the tune can you re-post with a lower t-stat over ride? (trying to trouble shoot before taking to dealer and thought that since the old tune w/ the t-stat fix was on the old throttle body a brand new tune w/ t-stat fix may fix overall-- also i logged data and got car to shut off while parked if you're interested.)
Many thanks,
David
