Update Troubles
Posted: Sun Jul 27, 2014 5:27 pm
by bofrazier9
Hooked up my inTune DCX to run updates and received the following message:
The current firmware revision (1r03x)
cannot be replaced by the firmware package
within Group_Update_1
No idea what this means. Then I press "continue" on the DCX and the following message is displayed:
Failed to install Group_Update.itfg
I press "continue" and I am back to the DCX home screen.
My current application is: 1r03x
DCX tune Db 1r01q(ok)
DCX PID Db 1r01b(ok)
FORD PID Db 1r01b(ok)
GM PID Db 1r01a(ok)
DTC Db 1r01a(ok)
VIN Db 1r01c(ok)
Info Db 1r01b(ok)
Bo
Re: Update Troubles
Posted: Sun Jul 27, 2014 5:52 pm
by bofrazier9
In addition to the info listed above, when I plug the DCX into my truck the DCX says I need an update.
Bo
Re: Update Troubles
Posted: Mon Jul 28, 2014 1:07 pm
run the updater again to correct this.
Re: Update Troubles
Posted: Mon Jul 28, 2014 7:03 pm
by bofrazier9
You seemed so confident in your reply, I actually believed it would happen.....guess what.....
Same error message:
followed by
Failed to install Group_Updates.itfg
This is really on my nerves. $400.00+ bucks and running updates has been a continual problem with the DCX; since the day I got it out of the box last year.
Bo
Re: Update Troubles
Posted: Tue Jul 29, 2014 11:09 am
did you try it again?
Honestly, it will indeed work, it has for every other intune user.
Takes less time to run it again than to come here and make a post :)
