Steeda CAI runs poorly in 2011 Mustang GT
downeytim
Post by downeytim »
I have installed the generic 100 mm 93 octane tune on my 2011 mustang gt 5.0. It has the Steeda Cold Air I just bought and Borla axle back S-Type exhaust. After the install of the tune the car is much less responsive. It acts like it is not getting enough of something at low rpm's below 2500. The power seems to come and go below that level. It also does not seem nearly as quick as the 93 octane performance tune I had one it before.
I have the ford_can_gas tunes loaded from the latest crom I loaded a few days ago.
Can anyone advise as to what I am doing wrong.
Re: Steeda CAI runs poorly in 2011 Mustang GT
can you post the tunes from the tool here?
downeytim
Post by downeytim »
here is the std 93 octane 100mm generic that I loaded.
PCM_FPDL9A5_Universal_100mm_CAI_93_Octane.frg
(3.25 KiB) Downloaded 302 times
downeytim
Post by downeytim »
Were you going to post me a new tune to load or are you just checking that one out? Just trying to see where we are going.
The car is running poorly, so thanks for your help.
sohfast94
Post by sohfast94 »
Could you get me a log at idle please?
Or a reading of the LTFT and STFT percentages will do fine as well.
Insert Clever comment here...
downeytim
Post by downeytim »
here is the log at idle you asked for.
TIM_DOWNEY.LOG
(37.1 KiB) Downloaded 309 times
sohfast94
Post by sohfast94 »
The only change between the regular 93 tunes and 100mm is the maf slope. Maybe the load calc is off. Try this.
pcm_fpdl9a5_universal_100mm2.frg
(543.07 KiB) Downloaded 313 times
downeytim
Post by downeytim »
The last one you gave me seems to be great when you open it up all the way. It is seriously quick. But it bogs down a bit at very low RPM's and it runs a bit rough when you are just cruising. It acts as if it is either starving just a bit or that it is wanting to go and you won't let it, if you know what I mean.
The standard tune has a very loud and deep additional tone from the engine than it ever did before, the Steeda I assume. But the latest tune you gave me does not have that sound. Don't care one way or the other just giving you info.
Thanks for the efforts so far. It is appreciated.
If you need some more information let me know.
sohfast94
Post by sohfast94 »
See if this is any better.
pcm_fpdl9a5_universal_100mm3.frg
(543.32 KiB) Downloaded 324 times
downeytim
Post by downeytim »
I am going on a long trip, 2000 miles round trip. Is the tune you sent me considered a performance tune, race tune, or something else? Is it ok to drive long distances with the standard 100mm tunes or this custom version you created for me?
sohfast94
Post by sohfast94 »
Just use the tune I posted it will be fine.
Return to “Trinity Ford Gas”
