I am about to install a wide band sensor in my 2006 Dodge Magnum SRT8 to log and view AFR for my Procharger build. I really don't want to run a second gauge in the pillar pod ( not sure it will fit with the Trinity in the lower hole as the Trinity just rests in the hole and doesn't fit all the way in the pillar pod ) and was planning on just running the Trinity as my only gauge.
Can I set up the Trinity to turn on at start up and go to the AFR gauge screen as a default to avoid buying a dedicated AFR gauge? If so, can it be set up to stay on the whole time the key is on (no timeout) and timeout when the key is off?
Trinity for full time AFR guage
Re: Trinity for full time AFR guage
yes, just leave it in monitoring with the afr gauge there and it will come up every time you start the car.
