Still can't disable Traction Control ...
Posted: Sun Sep 07, 2014 5:42 pm
by Brian13RT
I still can't disable my Traction Control via the Quick Adjust menu on my Intune DCX. I've read where this is also happening to others as well.
Is there a fix for this yet?
Re: Still can't disable Traction Control ...
Posted: Wed Oct 22, 2014 12:07 am
by hellrose1228
Same here.I have a brand new 2014 charger SXT plus 3.6/8spd. I get the "traction control failed to update" code every time.
Posted: Wed Oct 22, 2014 9:16 am
by Playhard
Not sure of this applies but on my 11 rt it only disables it for one run then resets once I turn the car off. It has to be repeated again and again with each restart of the engine. So its really only good for track day runs. To much work otherwise. Not sure if that's changed now with all the updates but I suspect not.
Posted: Fri Jul 17, 2015 11:10 am
by hellrose1228
Brian13RT wrote:I still can't disable my Traction Control via the Quick Adjust menu on my Intune DCX. I've read where this is also happening to others as well.
https://www.diablosport.com/forum/viewt ... 57&t=48802
