STANT 180 THERMOSTAT
Posted: Wed Sep 10, 2014 11:38 am
by HDSALES
ican you help me with the settings on this stant 180 thermostat
that I am putting in my truck, I have a trinity t-1000
thanks
Re: STANT 180 THERMOSTAT
Posted: Fri Sep 26, 2014 12:15 am
by johnny248
HDSALES wrote:ican you help me with the settings on this stant 180 thermostat
thanks
Are you referring to fan settings??? I have a Stant 190 Thermostat in my truck and removed the clutch fan. I lowered the fan turn on settings to 199.something. I figured 10 degrees over the t-stat should be ok. The OEM stat is 203, so I figured that my setting is pretty good unless someone else has some better info than me. Some people run it lower, but they mainly turn on when you are not moving. While my truck is running, say on the hwy the temp always runs how it should thanks to air flowing through the grill and the fan only kicks on if I am sitting at stop lights or something like that. If you are referring to other settings, then I have no idea lol
good luck!
Posted: Sat Feb 07, 2015 2:24 pm
by Ramrt1
I would think setting the value to the degree thermostat you have installed would your choice, I have a 180 stat installed and that's where I will be setting mine.
