2015 GM support released!
We have added support today for 2015 Camaro (V8 models), CTS-V, all 15 V8 gas trucks, and the 2015 Corvettes!
inTune will auto update then you may tune these awesome rides as you please.
Enjoy!
Enjoy!
Re: 2015 GM support released!
Is the ZL1 included ?
Yes, it isracered wrote:Is the ZL1 included ?
Just want to verify that the '15 CTS 2.0t is included? I see on this page that it says 2013-2015 CTS, but I don't see that in your post here. I found your tuner from your post on the Cadillac forums but figured I would double check. Thanks
Yes, all ATS/CTS 2.0T models are currently supported
Stellar! Thanks for the FAST response! You have a new customermikel wrote:Yes, all ATS/CTS 2.0T models are currently supported
I have the inTune for my 2014 Chevy SS sedan and am wondering if the torque management can be adjusted in increments (%) or if it's all or nothing with the 6l80e tranny and LS3 motor. Please advise, for I have read that you do not want to eliminate TM completely with these transmissions. Is there any TM in the canned tunes or has it all been removed?
TM is reduced quite a bit in the canned tunes, and there is a bit left in the tcm that you can disable if you choose.
Okay, I have a CMR tune from Lew. He said he disabled the TM in traction control...I'm assuming that is a diferent parameter than the rest of the TM, is that correct? I need to find out from him if he took any more TM out of the tune, but he is out of the office due to surgery. If I send you the tune, can you look at it for me to make sure that I still have a safe amount of TM?
all TM is disabled... no issues, perfectly safe...
the setting is either on or off.. there's nothing in between... and it is set to off/disabled...
Lew, are you referring to disabling the TM just in traction control or ALL TM in the tune?
Is there any cmr that are tuning ats 2.0t ?
Hemifever trinity , varam , 87mm tb ,stat , catch can , magnaflow , arheaders
13.4@101
13.4@101
I just purchased a 2015 SS sedan with the 6mt, if I upload the backup of my pcm will you be able to release tuning for it? Really enjoyed the 91 octane tune on my '14 automatic.
Yes, if your current calibration isn't supported, please read the backup and email it to [email protected] and we'll get it added for you.
Can I adjust the Fans to stay on for a min or two after the key is turned off for at the drag Strip ?
